Message 1 of 9
Creating an additional email
I want to create an additional email for my BT account and it says I can create up to ten email on a standard account.  However in the BT ID dashboard the button for creating another email is not where it says it should be on the help section of the website. It is not there at all. I am in the manage emails part so I believe this is correct.
8 REPLIES 8
Message 2 of 9
Re: Creating an additional email
I'm not sure why you think that managing emails is the right place to be to create a new account but never mind.
Try Account Information | BT.com
Message 3 of 9
Well if you follow the instructions from the BT website it’d show you that to add an ADDITIONAL email to the one BT account, which I already have. Then it is in the manage emails section. If you could see the red circled button in the photo. This is the button I am missing. But thanks for your comments.
Message 4 of 9
You should log onto your MyBT and then go to "Your Products" then "Email Manage". This should open a new page showing how many email accounts are already associated with your account.
There should be a box "Create New Email address".
Before you can create more than one email address you must have at least one email address already associated with your MyBT.
See link
How do I create and activate a new BT Email address? | BT Help
If you are a new customer, if there is not an option to do the above it could be that "Your Products" has not been fully populated yet. This can take a few days and your order for broadband must show as completed in your MyBT.
Message 5 of 9
Did you even try the link I posted?
Message 6 of 9
Hi, Yes I have already done this. I have been a customer for over ten years. The box just isn’t where it is supposed to be. I just get the option to go to favourite mailbox.
Message 7 of 9
This is what I see when I follow that link I posted.
If I then click manage E-Mail addresses, I am prompted to logon after which I see the screen below
As you can see the Create New button is there. Are you signing on with the primary BT ID or with one gifted to you by the account holder?
Message 8 of 9
If you do not have that option there is apparently something wrong with your account.
It may be that BT are wanting to stop the creation of new email addresses although that has not yet been confirmed.
Broadband ISP BT to Scrap Email and Cloud for New Customers - ISPreview UK
I have notified the moderators of the forum about your problem. Once they have read this they may be able to help. They are very busy at present so it can take up to 24 hours for them to contact you. They will do this by posting on this thread.
Message 9 of 9
Hi @martyn1969,
Thank you for posting. I'm sorry if you haven't been able to create a new email address.
If you send me your details, I'll be able to get this investigated.
I  have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
