Message 1 of 6
Delete Button.
The Delete button has disappeared from the top toolbar on Mrs. N's email page.  Mr's N is a numbnut with PC's and I'm only very marginally better so unable to help her get it back.
5 REPLIES 5
Message 2 of 6
Re: Delete Button.
Have you tried logging off from her email account and then logging back on?
Message 3 of 6
Re: Delete Button.
Hi @John_N is she using BT webmail or another program to view her emails?
Neil
Message 4 of 6
Re: Delete Button.
We both use BT mail.  This is from my screen, the delete button at the end has disappeared from Mr's. N's.
Message 5 of 6
Re: Delete Button.
I suspect she has changed the font size in the browser. Is it there if you click on the 'more' drop-down?
Message 6 of 6
Re: Delete Button.
Looks like we might have solved it.  There seemed to be some sort of advertising block compressing the available width (Mrs. N prefers a square format screen) for radio buttons.  Anyhow, we got something off Google, tried to follow it and the block disappeared restoring the delete button.  Fingers crossed.
