Message 1 of 10
EMail....Saved Successfully!
When logging in to my emails for a few seconds a white box appears at the top of the page saying 'Saved Successfully'.
Any ideas what this is about? Please.
9 REPLIES 9
Message 2 of 10
Re: EMail....Saved Successfully!
Hi @EJB,
Thanks for posting up your question.
Are you using our website when you're logging into your emails?
Do you have any emails in your drafts folder? If yes, is there one showing todays date?
Thank you
DanielS
Message 3 of 10
Drafts folder is empty.
I sign in to bt.com etc.......
The EMail programme is the latest/new version.
Thank you.
Message 4 of 10
Is there a way that you can grab a screenshot or screen record and send it to me privately?
Also, can you make sure that you've tried other devices, browsers and tried accessing it using InPrivate or Incognito mode?
Thank you
DanielS
Message 5 of 10
It doesn't appear when using 'In Private'.
It only shows for about 1 second so no screenshot.
Need to step back for a day so will respond again after tomorrow.
PS. Just tried my laptop...it has the new email layout since I last used it a few days ago. It too has the same ''Saved Successfully' box.
My second full time .desktop has not yet been updated and doesn't have the same anomaly .
Message 6 of 10
Thanks @EJB.
You will have been moved to our latest version of webmail but the issue that you're sharing seems unique.
Can you make sure that you have deleted your cookies and cache on both devices and try again when you get a chance.
I'm off tomorrow but any of the other moderators can reply back to you if you reply then. I'm here on Wednesday.
Thanks,
DanielS
Message 7 of 10
@EJB , @DanielS and other moderators
I also saw the "Saved Successfully" message for a while after I was moved to the latest webmail version.
It disappeared after a few days and has not returmed. I know that at some point I deleted all BT cookies so that might have helped. I'm using a laptop, Windows 10 and Chrome.
Message 8 of 10
Message 9 of 10
Visited a couple of relations and they too have the same anomaly....different parts of the country but Windows 10/11 and all BT.
In the next room my other half .....with all the same set up...doesn't have it!
Have cleared the cache on all machines!
I'm happy to wait and see what happens but will respond if it changes.
Thanks to all.
Message 10 of 10
It's not unique, the same thing has happened to me over the past week. Every time I open my BT email, no matter what device I use, whether home or work, a small box saying "saved successfully" briefly pops up and then disappears.
