Message 1 of 4
Email Log In Issue
Recently upgraded Windows on my PC from Windows 10 to Windows 11. Then the first time I tried to log into.my BT email account,  it went straight  to the error message:  'btmCode=bmx_2002.
Any advice?
3 REPLIES 3
Message 2 of 4
Re: Email Log In Issue
I have the same issue. Windows 10 did an auto update and now I get btmCode=bmx_2002
Sometimes it logs in ok but most times I can no longer access my email. BT seem to have lost the plot.
Message 3 of 4
Hi @myissues & @martin2000,
Thanks for taking the time to report this.
The first step to try is to delete your cookies and cache. After that, reset your password by logging into https://www.bt.com/mybt and go to the email manage section.
If you're using @talk21.com, and you still can't get in, please try changing how you log in. For example, if you used [email protected] you would now use [email protected] to log in.
Let me know how you get on.
Thank you
DanielS
Message 4 of 4
Still doesn't work for me. Partly because the moment I land on the sign in page, it bumps me to the page saying I have a Code=bmx_2002
