Message 1 of 3
Email account locked
Email via app on phone works perfectly.  Tried logging in to both main and sub accounts on my Mac and getting Red Account Locked message.  Cleared cache and I know both usernames and passwords are correct as I use a password app that keys them in.  Also typed in manually.  Why the error as nothing has been entered incorrectly?
thanks
2 REPLIES 2
Message 2 of 3
Re: Email account locked
Hi @Bodysm,
I'm going to send you a private message so we can look into this for you.
There may have been too many attempts to access your email through our website which is causing that lock. I can have it removed letting you get back in through a web browser. In the meantime, you should be able to use the app.
Thanks,
DanielS
Message 3 of 3
I have replied separately, but all appears to be working now.  Maybe it was a one-off on the day I saw the issue.
Thanks for your help.
Regards, Steve
