Message 11 of 22
Re: Email, changing to IMAP from POP3
That is exactly what I did, several times, but still not connecting.
I have checked and double checked the settings and they are exactly the same as on the link.
Message 12 of 22
I will ask if one of the mods can assist, sometimes the mail servers don't sync passwords properly.
Message 13 of 22
Many thanks for your assistance, doing this is a very frustating experience, hopefully once resolved never to be repeated.
Message 14 of 22
Might be useful to try another mail client. That might narrow the problem down.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 15 of 22
Have you selected the correct password options? e.g. the  'SMTP server requires authentication' box should be checked and the password should be entered whereas the 'Secure Password Authentication' box should be left clear
Message 16 of 22
Hi @mavis575, welcome to the forum and thanks for posting.
I'm sorry you're not able to change this so I've sent you a Private Message so you can get in touch with the mod team and we'll be happy to help you fix this.
Cheers
John
Message 17 of 22
HI, yes, selected all the correct options.
Message 18 of 22
Did you contact the mods via PM as invited?
Message 19 of 22
Hi, yes I have contacted them a few moments ago.
Message 20 of 22
They will get back to you in due course when you reach the top of their queue.
