Message 1 of 7
Email display name
How do I change my display name in my email account ?
6 REPLIES 6
Message 2 of 7
Re: Email display name
Depends how you are sending it.
If from webmail, click on your username in the top right corner, select settings, select profile, select edit. Change it to whatever you want displayed then click save. If from a mail app or client, you need to specify which one.
Message 3 of 7
Thanks @licquorice  in bt webmail and bt app my profile name does not match my display name in the from field when someone receives my emails
Message 4 of 7
I never use either, but worked for me as a test with webmail.
What name is being displayed for you? Don't post the actual name, just the format.
Message 5 of 7
I have same issue,  have tried following edit settings etc, but nothing comes up to change.
Message 6 of 7
Hi tried this, but can't see any edit option. Have tried in Outlook, webmail and BTmail... help.
Message 7 of 7
Hi @FlowerA I'm sorry to hear that you're having trouble changing your display name on your account.
We have a handy web page which gives more information on how to change your display name, just click this link here
Chris S
