Message 1 of 26
Email not available
Does anyone know what the "issues" are that BT are experiencing which mean no access to emails?
25 REPLIES 25
Message 2 of 26
Re: Email not available
You will need to supply more details such as where you are getting the message about "issues"?
How are you trying to access your emails?
How long has this been going on?
Message 3 of 26
Thanks for response. Message received when attempting to access BT emails on desktop. However subsequently discovered I can access emails on mobile phone. May therefore only be issue relating to the desktop. "Issue" only since this afternoon.
Message 4 of 26
It may be a server issue. I would strongly suggest that you do nothing and in particular do not try changing passwords or deleting the account.
It will most likely sort its self out.
If it doesn't sort its self out try restarting your computer and if that doesn't resolve it try turning your BT Hub off for about 30 minutes and when you turn it back on it will have been issued a new IP address and hopefully connected to a different email server.
Message 5 of 26
Many thanks.
Message 6 of 26
Came here to look for any notification about a service outage as all of our mail accounts are down right now.
We appear to be lacking a service status page from BT for email which is a critical service.
Message 7 of 26
Trying to access mail via desktop and get this message-
' We are experiencing issues with the service, please try again later.'
Why do they not put a message out on social media & explain there is a problem???!!!
Anyone with an idea as to how long this is likely to last?
Message 8 of 26
Re: Error message Cannot Send Mail
Since yesterday I cannot send any emails. I get an message " We are experiencing issues with the service, please try again later."
Message 9 of 26
Hi all.
Are you able to log into your BT Email now, or are you still getting the same error message?
Chris
Message 10 of 26
Chris, I was able to eventually log in yesterday however the same issue arose this afternoon (with same message). I have since managed to get back in again.
