Message 1 of 8
Email not loading on iPad.
Using my iPad I can log into MyBT but cannot log into my email account. On my iMac and android phone all works as normal. What’s going on?
7 REPLIES 7
Message 2 of 8
Re: Email not loading on iPad.
Are you a BT Broadband customer or are you paying for your email account through a BT Premium email account?
How are you accessing your email account on your iPad, is it with a web browser or with and email client/app?
What happens when you do try to log in?
Message 3 of 8
I am a BT broadband customer.
 I log in using a browser which is Safari
When I log in fron MyBT it starts loading but never completes. I did an operating  system upgrade and it did load once but subsequent attempts failed. Since BT changed the log in system things have got difficult as I often had to sign in three or four times a day in spite of ticking the box to stay logged in. No problems on iMac or android phone.
Message 4 of 8
Hi @Terry1937 I'm sorry you're experiencing issues with your BT email. What operating system version is your iPad running now? It needs to be 13.X or above to be compatible.
Neil
Message 5 of 8
Hi Neil
Im running 15.8
Terry.
Message 6 of 8
Hi @Terry1937,
Using Safari 15.8 should have no issues as we support it currently on iOS Safari 13.x and above.
Can you download the BT Email app from the app store and sign into your account there? Does that run smooth on your iPad?
Thank you
DanielS
Message 7 of 8
I have downloaded the app and attempted log in from that, which after 10 minutes loaded. But subsequent attempts have again failed to load. Will a reset of my iPad help? Or can anyone suggest a different approach. All very frustrating as I had no problems before BT changed the log in procedure.
Tags (1)
Message 8 of 8
Have you tried using the BTMail direct logon page
BTMail
