Message 41 of 92
Re: Email not syncing on Android
Thanks all for posting.
We're investigating this and will post whenever we have anything to share.
Cheers
David
Message 42 of 92
All, like many others I hit this problem last week. Deleting the mail account and adding it again clears the problem for a short time. Today I figured that the last thing I did before the problem started each time was forward an email. So I tried some testing here and it appears either forwarding or sending a new email causes the sync to break. If you then delete the forwarded/sent email from sent items, it appears to clear the problem and it starts syncing again !!
Message 43 of 92
Lo and Behold indeed!  Mine now fixed too - thank you!  Alan
Message 44 of 92
I have had the same problem this week. I am having to delete and reinstate my account almost daily on my android phone.
Message 45 of 92
At the moment my emails are showing..but I have had to delete my account from Gmail and then reinstate it twice today. I will check on the web page before doing this next time and let you know.
Message 46 of 92
Message 47 of 92
Spoiler
PeteHr  FWIW my Gmail on my Android performing in exactly the same way.
Message 48 of 92
Thank you!  To be honest, I didn't this would work.  But I have deleted recently sent and forwarded emails and it is now syncing!!
Message 49 of 92
I have the same problem. I deleted the account from my phone and re-instated it and all the e-mails appeared. Thought that had solved it - but no - subsequent e-mails did not appear. I appears that the only time it will sync is when it is being installed. Gmail appears to be syncing as it reports the time the last sync process was executed. So, I assume the BT end of the process  is not behaving.
Message 50 of 92
Why would you assume that?
