Message 1 of 7
Emails in inbox have disappeared
Hi,
I went into my inbox to view emails yesterday and a load had disappeared (some being quite old and left there as wish to go back to them).  Looked in deleted and not there.  Any way these emails can be retrieved (they disappeared between 1600 and 2200 hours?).....  Cant find using my mailapp on iphone or logging into BTemail either.  HELP!
6 REPLIES 6
Message 2 of 7
Re: Emails in inbox have disappeared
Hi
I have a similar problem but on just one of my four email accounts (the other three are okay).
Several years worth of emails have disappeared in the Inbox but all of the Sent emails are still there!
Any ideas would be much appreciated.
Message 3 of 7
Emails disappeared.
Hi,  i raised this last week but no response  pls can you indicate how j can ger this resolved
I went into my inbox to view emails yesterday (28th July) and a load had disappeared (some being quite old and left there as wish to go back to them).  Looked in deleted and not there.  Any way these emails can be retrieved (they disappeared between 1600 and 2200 hours?).....  Cant find using my mailapp on iphone or logging into BTemail either.  HELP!
Message 4 of 7
Re: Emails disappeared.
If they are not in your BTMail email account when you log onto BTMail using a browser it means that they have been deleted from the BT email servers and can not be recovered.
Message 5 of 7
That may be the case but i didn’t delete them so would like an explanation from BT as to how they came to be deleted. I definitely didnt
Message 6 of 7
All BT will be able to do is to tell you which device triggered the deletion.
I have notified the moderators of the forum about your problem. Once they have read this they may be able to help. They will advise you by posting on this thread.
Message 7 of 7
Hi RR2 and welcome back.
I'm sorry you've lost a number for your emails. If you can't find them on webmail then it's unlikely they can be recovered. I'll be happy to check that for you. Check your inbox for my message and drop me over the details.
Cheers
David
