Message 1 of 6
Emails indenting
My emails have started indenting. The incoming mail has a blue line next to text at left side,  when I type my reply the text goes further to the left past the blue line, I have tried settings, mail and unticked rich text unfortunately this has not solved my problem. This is happening on windows 10 on desktop, any advice would be most welcome
5 REPLIES 5
Message 2 of 6
Re: Emails indenting
@mar53
What e-mail client software and version are you using ?
Microsoft Outlook ? Thunderbird ? Gmail in a browser ?
it is an easy to resolve issue but we need to know more about your set-up.
Message 3 of 6
It's bt mail
Message 4 of 6
@mar53
Sorry, cannot help, not a BT Mail user myself.
Message 5 of 6
Hi @mar53
Welcome to the community and thanks for posting, you can decrease and increase the indent in your reply using the two buttons I've highlighted with the arrow.
I hope that helps?
Neil
Message 6 of 6
Thank you 😊
