Message 1 of 4
Emails not displaying
If I hover the mouse over INBOX there are approx 1500 emails, but only six are displayed ranging in date from mid to late August but nothing before or after. I have received an email this morning so I know that the system is working correctly. I have the same problem with SENT folder where there are approx. 1200 emails of which only six are displayed. This problem has only occurred since yesterday afternoon and is the same across all my devices. Any suggestions would be greatly appreciated.
3 REPLIES 3
Message 2 of 4
Re: Emails not displaying
Hi @snowey are the emails there if you log in on the BT webmail site?
Neil
Message 3 of 4
Hi Neil, thanks for replying. No, the old emails do not display using BT email, though if I use another email app they do seem to display.
Message 4 of 4
Hi @snowey,
Thanks for replying back to Neil. I'd like to look into this a bit more and perhaps speak with you to find out what exactly is wrong and if it's something that we can help you with. I have sent you a private message that you can reply back to. Please note, it may take us a few days before we can get back to you after you reply to my private message.
DanielS
