Message 1 of 8
Error 553
Like others I cannot send emails from home when previously I have had no problems. It is error 553. Any suggestions?
7 REPLIES 7
Message 2 of 8
Re: Error 553
Hi @Keyzy,
Welcome to our Community.
I am sorry to see that you're experiencing problems with sending some emails.
This error can usually be caused by the contents of your email or by the amount of people that you are emailing.
Have you tried logging in through https://www.bt.com/mail and sending the email from there?
Thank you
DanielS
Message 3 of 8
Re: Error 553
Yes - same problem when logged in from there
Message 4 of 8
Re: Error 553
Hi @Keyzy
Thanks for posting back!
I am sorry you're having these problems.  Are you connected through a VPN?  If so, disconnect and try sending the emails again please.
Thanks,
Robbie
Message 5 of 8
Re: Error 553
What is a VPN and how do I disconnect?
Message 6 of 8
Re: Error 553
If you don't know what a VPN is you won't be using one.
Message 7 of 8
Re: Error 553
So I am no further on. I cannot send any emails!
Message 8 of 8
Re: Error 553
Hi, @Keyzy I'll send you a private message so you can contact the moderation team and we'll be happy to get that looked into.
Neil
