Message 1 of 4
Filing emails
How do you undo an action when you have selected to file an email and by scrolling down you have unknowingly touched a box you did not want, and have to search the entire alphabet for the misfiled email
this is my iPhones being over sensitive
3 REPLIES 3
Message 2 of 4
Re: Filing emails
You can not undo it. All you can do is find it and place it into the proper file.
Anonymous
Not applicable
Message 3 of 4
Re: Filing emails
I would expect there to be a search facility so you can search for a keyword in the email or the sender.
Message 4 of 4
Re: Filing emails
