Message 1 of 3
How to get BT emails deleting on all Mac devices. Help needed
Hi
I've had a look at past  posts on this, but still need a steer/advice please.
I'm using various BT emails on Macbooks, iphones and ipads. I'm using Mac Mail and Outlook email on the laptops
I want to set them to delete emails across all devices when you choose to cull on just one device.
I've looked at my email settings and I have a IMAP accounts, but need advice from there.
What other settings are needed please ?
Many thanks
2 REPLIES 2
Message 2 of 3
Re: How to get BT emails deleting on all Mac devices. Help needed
All your devices need to be set up as IMAP using the following settings.
https://www.bt.com/help/email/manage-email-account/manual-settings/what-are-the-settings-for-outgoin...
Once you have done that they should all synch with each other.
Message 3 of 3
Many thanks will try that
