Message 31 of 53
Re: I am unable to send emails, they get stuck in my outbox.
It's not clear if @PETER_DANT is referring to webmail which obviously doesn't or the BT mail app which does.
Message 32 of 53
I was referring to the BT Email APP and not Webmail…..
I was advised by BT to  look at my PROFILE picture and click on it !
Check that your email address is correct
Make sure that FIRST name is correct
Make sure that LAST name is correct
That seemed to cure the issue BUT it still does it !
Message 33 of 53
Uninstall the BT mail app and use a proper one.
Message 34 of 53
How was it resolved please ?
Because I am still experiencing this issue with my iPhone 14 on the BT Email App !
Message 35 of 53
Me too !
Message 36 of 53
I suggest you refer to messages 21 and 23 on this thread.
Message 37 of 53
Still happening so not fixed
Message 38 of 53
BT need to get their act sorted. They block whole ranges of IPs and never reenable them. I am sick and tired of having to turn off wifi on my phone to send an email. FIX IT BT.
Message 39 of 53
Please can you say what you mean when you say "they block while ranges of IPs"?
Also how does turning off wifi on your phone specifically help? That doesn't alter any IP address for your wifi.
Message 40 of 53
Presumably when he turns off his wifi on his phone he then starts to use the mobile network on 4/5g rather than his home network. This will use a different IP address than his home network and the mobile network's IP address  would appear to allow the emails to work.
