Message 1 of 3
I presume this is a scam?
I received the following email, supposedly from someone called Somiya Said (at arabdt DOT com).  I have presumed it to be a scam and reported it as such  - I would never follow a link in an email and wouldn't expect BT to sent one like this.  In the message below the word VERIFICATION replaces a link.  Just thought I would double check on here and see if anyone else has received similar.
Maria
myBT
We apologize for the inconveniences. We recently upgraded our database system, So we kindly advise you upgrade your mailbox today by Clicking VERIFICATION to avoid being locked out of your account..
Sincerely,
Thank you for understanding
myBT Secure Email Services
2 REPLIES 2
Message 2 of 3
Re: I presume this is a scam?
Hi @MariaH,
Thank you for taking the time to share that here and for also reporting it.
You did the right thing reporting it as that email is 100% a scam message.
We will never ask you to upgrade your own mailbox through a link. If we need to make changes, we will do them at our end and you will see the result when you log in.
Thank you
DanielS
Message 3 of 3
Thanks Daniel
I thought as much - hope this helps warn someone else too,
Maria
