Message 11 of 19
Re: Import existing email folder structure and messages into gmail
@licquorice wrote:
@gg30340 wrote:
They could try setting up an email client with both accounts and dragging and dropping the folders/contents from one account to the other.
It works just fine in Outlook 2010, I do it all the time, I'm sure it does with other clients too.
I just tried it on T'bird and it worked there as well.
Message 12 of 19
Google will download new BT emails sent to my BT account
How did you achieve this? At least that is a step in the right direction!
Message 13 of 19
In your BTMail account settings set up "forwarding" to your gmail account.
If you are leaving BT Broadband, your BTMail account will become a BTMail Basic account and while forwarding may work at first it can be stopped at anytime by BT.
Message 14 of 19
Thanks I was aware of that
But I want to be able to access the sub folders I have setup under the inbox
If you are able to do that with a basic account that would make it easier if I do leave BT
Message 15 of 19
Hi
BT would not let me forward received emails automatically so I set up my Google the receive emails sent to my BT email address
I set it up in my gmail account
Go to email settings  and go to the Accounts and  Import tab then scroll down to the Check emails from other accounts
Message 16 of 19
If all you are doing is using webmail the BTMail Basic account is exactly the same as the "Standard" account that you have at the moment.
Except you won't be able to use it on email clients or email apps and you won't be able to set up any more BTMail email accounts.
Message 17 of 19
@johnld wrote:
Hi
Was this after you had left BT Broadband and your BTMail account was BTMail Basic?
I have just set up forwarding to gmail using a "Standard" BTMail account and it works without issue.
Message 18 of 19
I have not left BT
Message 19 of 19
@johnld wrote:
I have not left BT
In which case there should be no reason why you can not forward your BTMail to a gmail account. As I said I have just done that as a test and it works without issue.
