Message 1 of 3
When log in it takes me to a screen with options which include log in to My BT. So end up in a circular process. It’s the same using APP and web.
have cleared cookies etc  reset password and still the same.
how do I get logged on?
2 REPLIES 2
Message 2 of 3
Re: Log in
Solved.
doesn’t like VPN
Message 3 of 3
Re: Log in
I tried to login and got send the BT website - it totally ignored me. After several attempts I finally got into the webmail, so being sent in loops may not be due to a VPN because I do not use one.
