Message 1 of 4
Lost Email Access, Can't reset password
Hi,
Lost access to my email - getting messages saying I need to reset passwords etc. I've tried several times going through the procedure and have got to the "reset password" stage but despite using a brand new password I keep getting "something went wrong" message.
I've also tried phoning for help but none of the press 1 etc options are for email. Going crazy!!
Any suggestions
Thanks Alan C
3 REPLIES 3
Message 2 of 4
Re: Lost Email Access, Can't reset password
Hi @alchad welcome back to the community. I'm sorry to see you're having problems with your email password. I can see you've a @talk21.com email from the community registration. When resetting your password you need to format it like this [email protected] instead of [email protected]
Let me know if that helps.
Neil
Message 3 of 4
Neil,
Thank you for that.  You have started a few bells ringing in my old head!   I had this problem quite few years back and I seem to recall that the emil was part of the problem/solution. I think I half got in just now but managed to mess up the new password and have been locked out for 20 minutes before I can try again. Thanks for jogging the memory😀. Will report back.
Regards
Alan C
Message 4 of 4
Worked! Got password reset, thanks for the help.
