Message 2 of 6
Mail server not responding
On my Apple iphone email I am getting "Cannot get Mail, the mail server "mail.btinternet.com" is not responding.
I’m having this issue following holiday in Vegas. Now in Cancun and cannot access emails via iPhone. Tried to login via desktop but sends a verification code via email which I obviously can’t access.
Not back in UK until 27th May and need to access emails re flights home etc .
Just wondering if anyone could help to get this issue resolved?
5 REPLIES 5
Message 1 of 6
Re: Mail Server not responding
I’m having the same issue following holiday in Vegas. Now in Cancun and cannot access emails via iPhone. Tried to login via desktop but sends a verification code via email which I obviously can’t access.
Just wondering if you had any luck getting this resolved? Thanks
Message 3 of 6
Re: Mail server not responding
Hi @heleny1 welcome to the community. I'm sorry to see you're having problems accessing your BT email when on holiday. Are you using a public wifi connection at the moment? The most common reason for this happening is due to the IP address of the public wifi being on a blacklist.
If possible can you try an alternative connection, also if you haven't tried already I'd also recommend using the BT email app to see if you can access this way?  You can download it from the Apple store on this link.
Neil
Message 4 of 6
Hi Neil, thanks but unfortunately I only have access to public wifi until I get back to UK.
The BT Mail app is not working for me either
Message 5 of 6
Message 6 of 6
Brilliant, that has worked.
Thank you so much!!
