Message 1 of 4
Mark emails as read
Hello
Using the email app on my iPhone.
after I select all mails, where do I find the menu button to select mark all as read
after selecting all, the only option showing is to either flag or select the eye.
i have looked at this so many times
thanks
3 REPLIES 3
Message 2 of 4
Re: Mark emails as read
Hello @juliaharries.
Have you tried clicking the small box at the top of the list of emails?
This should select all the visible emails, you will then need to go to the menu at the top and select 'more' then 'mark and read'.
Speak soon,
Katie
Message 3 of 4
Unfortunately there is no small box that is visible.
i only have a flag and an eye with a strike through it.
Message 4 of 4
Uninstall the BT mail app and use the built in iPhone mail app.
