Message 11 of 29
Re: New Email Format
Don't like the new format, however it workable.  Biggest issue is that text very frequently jumps back to the beginning of the message - this is very annoying and should not be happening.  How to solve?
Message 12 of 29
  1. Agree with the jumping of the cursor
  2. Very slow indeed
  3. Search facility for emails very poor
  4. Losing emails
  5. Frequent requests to log back in
  6. Helpdesk call said "we have no problems, please try removing all cookies and enter mail through bt.com portal
  7. Terrible jumps in font size as if each new paragraph was an indent in MS Word
  8. Very clunky management of emails
  9. Don't try filtering by day or priority - murderous
Otherwise perfect (LOL). This introduction is absolutely disgraceful. But if you switch, beware, BT won't transfer your email history....
Good luck going over the top, men, as they said in Blackadder.
Message 13 of 29
As I keep saying to no avail, I have no idea why you don't just use the right tool for the job instead of the bodge of webmail.
Thunderbird and EmClient are free to download and install and will give a far superior interface.
Message 14 of 29
Thank you very much Liqorice!
I’m thinking using those browsers will not lose me my BT emails and contacts. Beginners’ question I admit.
Message 15 of 29
You can export your contacts from webmail and import them into Thunderbird or EmClient.
It's not an either/or situation, you can use webmail as well as mail clients. If you configure the clients as IMAP, everything is always in sync.
Message 16 of 29
How about selecting 400+ emails to move to a new folder???
Message 17 of 29
What about it?
Easily done with a mail client.
Message 18 of 29
Now the text on incoming emails is  broken up,   so words at the end of each line are cut randomly and carried over on to the following line so reading has become a syncopated experience. Have tried in vain to rectify, increasing and decreasing the size of the page, gone to full page,  different views ... nothing works.
Aaaargh!!!
Message 19 of 29
See message 13
Message 20 of 29
What please, does that even mean???
