Message 1 of 5
Problem with New Outlook
I use Microsoft New Outlook and BT. Items sent from New Outlook do not appear in my email 'Sent' folder
4 REPLIES 4
Message 2 of 5
Re: Problem with New Outlook
Presumably the sent emails do show in Outlook but not in your BTMail account when using browser.
If you are using "New Outlook" and sent emails do not appear in your BTMail folders when you check using a web browser it would appear that you have set Outlook up as a POP3 account which does not synchronise the folders in Outlook with those on the BT servers that you see when you use a web browser.
You will need to set up Outlook as an IMAP account.
You can not swap a POP3 account to be an IMAP account. You will need to set up your email account again.
Message 3 of 5
Thanks for the response.
The emails do NOT appear in New Outlook– and New Outlook HAS been set up as an IMAP account
Message 4 of 5
Do sent emails appear in your BTMail sent folder on BT webmail when sent from Outlook and if you send directly from BT webmail do they appear in Outlook and BT webmail?
Message 5 of 5
Hi - Emails sent from New Outlook do appear in BT email - if done correctly.
Just found that New Outlook email 'Send' needs does not actually send them - which is confusing.
It gives two options - 'Send' and 'Start Mail Merge'./
Hopefully this has solved my problem.
Kind regards, Malcolm
