Message 1 of 19
Problem with portal
Hello, I am reaching out to you because I have the following issue: My uncle is trying to log in through the web portal but he keeps getting the ts-003 error (he is not using any VPN or proxy). However, when I connect through an email client like Thunderbird, I can log in without any issues. I am not sure if this is a bug in the web portal or if there is a solution to this problem.
Tags (1)
18 REPLIES 18
Message 2 of 19
Re: Problem with portal
Presumably you are accessing at a different address, if so, can you login via webmail as well as Thunderbird?
Message 3 of 19
Weird I'm not using different addresses, I've tried clearing cache, cookies, etc. But the problem persists. I've made sure that I'm using the same IP.
Message 4 of 19
I assumed you were at a different address and therefore different IP address and was trying to eliminate IP address as cause of problem.
As you are using the same IP address, try disconnecting the hub from line for half an hour or so to trigger a change of IP.
Message 5 of 19
I change my ip three times i dont know why all ips blacklisten. I guess some problem with spain ip.
Message 6 of 19
If you put the IP address into a IP address geolocator is the IP address registered in the UK?
Edit: just noticed you said the IP Address is in Spain? If so that is the reason, T&C's state it need to be accessed from UK. The error you see means you are trying to login to the BT account from a IP address that either not in the UK or from a known VPN - both actions will be blocked
Message 7 of 19
There is nothing wrong with logging into your BTMail email account when in Spain. Every time I have visited Spain, which is many times,  and many other countries I have had absolutely no problem from accessing my BTMail account.
Can you point out where BT state in their T&Cs that the email system needs to be accessed from the UK and can not be accessed using an IP address out side the UK and they will prevent BT customers from accessing their email unless they are using a known VPN?
All the T&Cs state is "it will be used mainly in the UK"  and "you permanently or normally live in the UK and you will tell us straight away, and stop using the service, if that changes".
Email terms and conditions (bt.com)
Message 8 of 19
@gg30340
Error code TS-0003 when logging into the BT Consumer Siteminder SSO gets invoked when you are either trying to login to the BT account from a known VPN or from an IP address not registered within the UK.
This only seems to happen when you try to access the emails by webmail (via the Siteminder SSO) and not by the IMAP and SMTP server.
https://www.bt.com/products/static/terms/oct2022btmail.html
As per T&C's of the service:
Special conditions that apply to the service
By using the service, you agree that:
  • it will be used mainly in the UK;
  • you permanently or normally live in the UK and you will tell us straight away, and stop
Message 9 of 19
Then i can't enter email from spain that ips is provide by isp i dont use any vpn.
You know some process to register ip, my uncle before lived in uk
Message 10 of 19
My uncle say leave permanly in the UK but he travels on business to spain often
