Message 1 of 6
Re: Email "An Unexpected Error has occurred"
Hello - I too am getting the "Unexpected error has occurred" when trying to access my btinternet.com Inbox.  All other folders are fine.  Any ideas on how I can fix this?
Ged
5 REPLIES 5
Message 2 of 6
Hi @kiwiged, sorry you were unable to access your inbox.
Are you still getting this error message?
Cheers
John
Message 3 of 6
Hi John - yes still getting error message on both an iMac and Macbook Pro.  Can access all Inbox emails on the phone though.
Message 4 of 6
I get this message from time to time, & i'm getting it now,i pause my vpn & i get into my email ok.After a while the message stops popping up,strange one this,if you use a vpn try pausing it.
Message 5 of 6
Hiya - do not use VPN. Cheers
Message 6 of 6
I mentioned earlier that this was a strange one because ,for me anyway happens for no apparent reason & suddenly everything works as "normal".My email & MYBT accounts are now ok when i'm using  vpn after 3 days of having to pause the vpn.
