Message 21 of 31
Re: Slow emails / Full Fibre
I've merged the thread with previous one to keep the conversation and advice in one place, as it's a unique query.
@David_W102 You've received great advice from @licquorice to follow.
I'm concerned you keep being pushed back to us by your new provider, so I've raised this with our email team to trace and confirm the best steps to take.
Once I hear back I'll let you know.
Ali
Message 22 of 31
I appreciate that - Thanks..
Message 23 of 31
HI @David_W102
Our email team have suggested it may be a client/account configuration issue rather than being only provider related.
Can you check the email you're using are configured to use SMTP authentication, and the password is correct- some versions of Thunderbird may gain multiple outbound/outgoing SMTP server configurations.
Please remove any duplicate/unwanted SMTP configurations and check the remaining ones are correct.
Please let me know how you get on, or if all the settings are correct but continue facing a slow sending response.
Which date did you move over to Toob?
Ali
Message 24 of 31
Well there's a thing. So now without doing anything, changing any settings, no switching things off and then on again ! My emails are moving again... How strange - It's almost as if someone read my email and sorted things out....... I guess we shall never know !
Message 25 of 31
Thanks for keeping us updated with this @David_W102
Our teams made no changes, as everything was working correctly our end, but they see the logs show less auth failures for both this and other mailbox access you have, and there are no instances of failed/rejected logins showing for you now either. Fingers crossed your broadband provider has resolved the issue for you permanently now.
Ali
Message 26 of 31
Re: SMTP stopped working after changing Broadband speed
Email sending problems have started up again. So since my last message emails were being transmitted ok but in these last couple of days problems have started. Emails are sent but the progress is very slow. Somewhere in the chain, there is some problem. Come on BT please sort this out so we can have a reliable email system...
Message 27 of 31
Have you reported the problem to your Broadband provider because it would appear going by the investigation that the BTMail team have reported that they have carried out that the issue does not lie with BT.
Have you checked the settings given above as was suggested by the BTMail Team?
Message 28 of 31
All settings are as they have always been (for the past ten years at least !), Both BT and my broadband supplier state that all is good. But strangly I'm having problems sending emails......... Must be something in the air .....
Message 29 of 31
Hi @David_W102
Thanks for coming back to us.
I've asked the email support team to take another look at this for you and will let you know once I have more information.
Leanne.
Message 30 of 31
Thanks for checking...
