Message 1 of 4
Re: You have had too many unsuccessful attempts to login.
Having the same issue here and have not changed anything, and I have stuff to do 😡
3 REPLIES 3
Message 2 of 4
Hi @mrstig and welcome back.
Good to see you again. Have you tried following the forgotten password route? Can you try that and let me know if it sorts the problem.
Cheers
David
Message 3 of 4
Hi I did not try that but what I did do was login to the main email account (as it was a sub account I was having the issue with) logged back out of main then tried the sub account again (without any password reset) and I got in straight away 😀. I hope this helps others with the same issue.
Message 4 of 4
Hi @mrstig
Thank you for posting back and confirming the solution to the problem you were experiencing.  I'm really pleased you're back in now 🙂
All the best,
Robbie
