Message 41 of 145
Re: Received email with no sender, no subject and message converted to plain text
Thanks, let's hope it works.  I have a question though, having worked in IT, and wonder how the error could have occurred as any changes should have been the subject of testing before implementation, thereby eliminating such issues.
Message 42 of 145
No point in asking me. I just happened to start this particular chain as I was affected by the problem. You’d have to direct your question to a moderator.
I expect to be getting a newsletter this week from my original sender (No sender), but this may not be until tomorrow or Friday.
I have been asked to report back to Leanne if there’s still a problem, but I am sure that anyone else could do so.
David
Message 43 of 145
Hi @MDTamar
Thanks for the feedback, as soon as we were made aware of the email showing incorrectly this was reported this to the relevant team.
If you receive any new emails with the same problem please let us know.
Leanne.
Message 44 of 145
Hello Leanne,
This issue seems to be resolved. My usual newsletter has come through showing the true sender and contents as normal.
Thank you for helping to sort this out.
David
Message 45 of 145
I'm really glad to hear that these emails are now sending correctly @davidym
Thanks for taking the time to come back and let us know too!
You take care,
Peter
Message 46 of 145
Issue does appear to be resolved.
I did get a call from the technical department, as I understand it, in order to counter spam the BT algorithm was updated to identify those (particularly those with a gmail address) who regularly send circular mail to large numers of users.
All very sensible - but the bit that I don't understand is that I had already idendified the originator of the main affected e-mails as a safe sender. Why on earth would I do that if it were a Spammer?
Message 47 of 145
I also have intermittently had this problem.
I use a MacBook Pro, my iCloud email address did not have the same problem.
The last occurrence of this problem was on 13th and 14th February 2025, subsequently it has cleared.
The senders were known senders from whom I regularly receive emails.
I notice that the 'no sender, no subject' emails were actually received correctly on my iPhone.
Message 48 of 145
Hi @davesurfworld.
Thanks for coming here.
If this occurs again please come back and let us know so we can get this investigated.
Katie
Message 49 of 145
I am now getting this issue - I have been in touch with BT and they deny any issues? If I configure Outlook 2021 with IMAP, it works ok. However with POP3 setup - get no sender, subject and text is in plain and virtually unreadable?
Message 50 of 145
Received email with no sender, no subject and message converted to plain text and unreadable.
This new issue has appeared within the past few days.
the from column is blank as is Sender, subject also shows as blank, whole message converted to plain text. and unreadable.
I normally view e-mail using OE classic or Thunderbird but this problem is not there when i log in to bt email on the web. - tried using Chrome and Edge, same issue.
my wife has a  btinternet address - she has just started experiencing the same problem.
seems to only be getting email on computer using email client program
