Message 61 of 145
Re: Received email with no sender, no subject and message converted to plain text
I have the same problem, it's very annoying but glad to see that I am not the only one
Message 62 of 145
Turned router off for 50 mins - 1 x E-Mail out of 15 came through ok but others still the same 😞
Message 63 of 145
tried that no change.
Message 64 of 145
Same problem here, even after turning router off for 40 minutes.
Message 65 of 145
Report it to BT and don't let them fob you off - it must be a BT issue !!!
Message 66 of 145
Tried router off for 30 minutes, still the same unfortunately.
Message 67 of 145
I have exactly the same problem, on both my own and my wife's PCs, starting yesterday afternoon.  Furthermore, our son has just phoned to say he is in the same boat!
We all use the Classic Outlook email client (POP3 protocol):
- all emails sent to my @btopenworld.com address appear in Outlook with no subject and no sender
- the body of the email is scrambled
- emails sent to my other address are fine
At the moment we have resorted to using BT webmail, where the messages show correctly, but this is playing havoc with my Outlook email filing system!   Interestingly the emails also show correctly in the Mail app on our iPhones.
Presumably this is a BT server issue of some kind...
Message 68 of 145
Re: Emails received full of gobbledegook with no subject or sender name
Thank you for pointing me to the other thread, which I had not seen!
Message 69 of 145
This is happening again, new current thread started 13/08/2025
Message 70 of 145
Both my wife and I have had this same problem using MS Outlook mail client since yesterday.
Just spoke to BT support who say that it is not an issue with BT Email servers but with MS Outlook (surprise, surprise).
However I have no problem at all with emails received from other email accounts (GMail and Hostinger) into the same MS Outlook client. There's clearly some BT server or a compatibility issue here.
Outlook is intermittently reporting Task ’[email protected] - Receiving’ reported error (0x800CCC90) : ’Your incoming (POP3) email server has reported an internal error. If you continue to receive this message, contact your server administrator or Internet service provider (ISP).’
Not holding my breath....
