Message 1 of 5
Reply to email
I can't reply to emails from my iphone, but I can from my PC.
I compose the reply and send but it just completely disappears.
This suggests a problem with something on my iphone I suppose but I don't know how to rectify it. It's only recently started happening, nothing else has changed.
4 REPLIES 4
Message 2 of 5
Re: Reply to email
How are you accessing your BTMail account on your iPhone. Is it with an email app and if so which one or are you using a web browser and if so which one?
Have you tried anything to try and resolve the problem?
Have you tried restarting your iPhone?
Message 3 of 5
Re: Reply to email
Hi thanks for your reply.
I'm using BT Email app on my iphone and yes I have tried restarting it.
Not tried anything else cause I just don't know what to try.
When it's happened and I'm needing to reply on my iphone , I attempt it, but end up going to my PC when I can and doing it on there.
Message 4 of 5
Re: Reply to email
Try uninstalling the BTMail app from your iPhone then restart the iPhone and reinstall the BTMail app.
Message 5 of 5
Re: Reply to email
Oh my god I think that's worked.
Just did a test from on an email on my iphone.
I was very nervous doing it all as I'm not too confident on tech, but it seems to have worked ok.
Thank you so much for your advice.
