Message 11 of 16
Re: Thunderbird BT email settings
Thanks for your response. I am setting this up for an acquaintance and am not sure of the background.
All I know is that he purchased a new laptop with Windows 11 on it and since then he has had issues trying to install and use an email client. First New Outlook and now Thunderbird. Prior to the new laptop, as far as I am aware, he had no issue when using Outlook on an old laptop.
I don’t believe BT is his Broadband provider but he obviously has a BT email account.
I am unclear what issue this may cause and whatever they maybe does it mean he can’t use an email client with a BT email address?
Message 12 of 16
If neither a BT Broadband customer or paying for his BTMail email through a BT Premium email account his email account will have been downgraded to a BTMail Basic account which can not be used with an email client
See link
https://www.bt.com/help/email/bt-email-products
Message 13 of 16
Thanks.
I will check with him, but I am sure he had Outlook running with this BT email address on an old laptop?
Message 14 of 16
@wairds wrote:
Thanks.
It might well have been because the system had not thrown him off when he stopped being a BT Broadband customer but the system will have checked when he tried to set up the email account again and "computer says no". It would not allow it to register.
That is assuming he does not have a BT Premium email account.
Message 15 of 16
My thanks to all who responded.
As my friend also had a gmail account, I set that up with no issue on Thunderbird. I then put automatic forwarding on his BT email account so he receives all his emails in one repository. Not ideal, but he is happy with the solution.
Thanks again.
Message 16 of 16
Be aware that forwarding on a BTMail Basic account can be stopped by BT at anytime without warning.
