Message 1 of 7
Trash folder has hidden messages?
I empty my Trash folder but it says there are still 3 files in there, but not visible in the folder. Any advice please? Thank you.
6 REPLIES 6
Message 2 of 7
Re: Trash folder has hidden messages?
Hi @Loveleecat, sorry you're been shown that 3 messages still exist after you've entered the folder.
If you haven't checked on webmail please login www.bt.com/email and check if it shows there and if so do the emails show there for you to delete or are they just' ghost' emails.
Cheers
John
Message 3 of 7
Hello John,
Just checked via the link you sent, emptied the folder and it now says there are 10 "hidden" messages.
Rgards,
Lee
Message 4 of 7
Thanks for getting back @Loveleecat .
Can you post a screen shot of what you're seeing (please edit any personal information before posting).
Cheers
David
Message 5 of 7
Hello David,
I've tried various formats to send the screenshot, but keep getting the message below.
Message 6 of 7
Hi @Loveleecat, what does the message say and we'll see if we can help you post a screenshot?
Cheers
John
Message 7 of 7
Hi John,
The message reads "The file type (.docx) is not supported."  The bit in brackets changes according to what format I am trying.
Regards,
Lee
