Message 1 of 5
Unable to send an email
Is anyone having this problem, it has never occurred before now. I tried to send an email to a group I am in but it would not send. Came up with error message and to check any URL links, content, as it could come up as malware, phishing etc. I checked through my email, took out any links but still this message appears.
Thanks for your help
4 REPLIES 4
Message 2 of 5
Re: Unable to send an email
Hello @Hazey.
Thanks for coming here.
Are you able to receive group emails OK?
Does the group have more than 49 recipient's?
Are you using the app or webmail?
Katie
Message 3 of 5
Kate, Thank you so much for taking time to email with your suggestions.
The group I am sending to will only have about 15 folks at most,  I took some of the links out and it was able to send without any links or URL.s
I have never had this happen before and was even worried it may have been something I had written, misconstrued in some way. I will not need to send again until beginning next month - so hoping all is well by then. Thanks again for your kind help
Message 4 of 5
Thanks so much for getting back to me @Hazey.
It would be great if you could keep us updated following your next email.
Katie 🙂
Message 5 of 5
I shall do Katie, but it will not be until beginning of December now, here is hoping...
