Message 1 of 7
Unable to send emails when on wifi
I am using iPads and iPhones to send my emails I periodically get emails being sent being blocked stating incorrect password when it is correct and will allow me to sign into my emails on safari etc and if I turn off wifi and use 5g etc . As soon as I connect back to my wifi server no longer works …….i have deleted the account reset it up , wiped server settings and set back up and still nothing
6 REPLIES 6
Message 2 of 7
Re: BT SMTP Server Fault
I’m having this issue now
Message 3 of 7
Re: Unable to send emails when on wife
I presume that is a typo in the title 🙂
Is it a BTMail email account you are using or are you using your own email domain and its servers?
If it is a BTMail account the correct settings are as per this link.
BT Email server settings | BT Help
It may be a server problem. Have you tried turning off your BT Hub for about 30 minutes. When you turn it back on it should be issued a new IP address and will most likely be connected to a different email server.
Anonymous
Not applicable
Message 4 of 7
Oh dear
Maybe editing the post would stop the mind boggling
Message 5 of 7
Posts can only be edited for up to an hour after it was posted. I will ask the moderators to edit it.
Message 6 of 7
I did try to amend the title . Love the word correct and me not checking …..!
I had to amend my password for the 5th time and now it’s working and so is the WIFI …..
Message 7 of 7
Re: Unable to send emails when on wifi
I think BT are over zealous in blocking IP addresses from ranges their security systems flag up. In order to fix this issue I had to resort to paying my ISP for a fixed IP address. This is unacceptable.
