Message 1 of 5
What does the following mean?
Hi Guys
I get that when I click on a short cut to a BT Email account?
Thanks in advance.
TTP Status 404 – Not Found
Type Status Report
Message JSP file [/index-rui.jsp] not found
Description The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.
Apache Tomcat/8.5.85
4 REPLIES 4
Message 2 of 5
Re: What does the following mean?
Basically it means that your search engine can not find the web page that you are looking for.
It could be a problem at your end such as you may have a stale short cut. Try the "email" button at the top of this page.
It could also mean there is a problem at the BT end which will no doubt be resolved so keep trying.
Message 3 of 5
If you are using a favourited page then I would go to the page from fresh and see if that helps. If not then I would clear your browsing history or change your browser.
If that does not fix it it is likely to be an issue at BTs end
Message 4 of 5
400 series errors are on the client-side.  (500 are on the server-side).
Message 5 of 5
Thanks guys.
