Message 1 of 4
email on outlook
hi guys just quick update on outlook for win 11 android and Mac when creating you're outlook using bt email make shore you are using pop as the other imap and won't work via the new security  and setting in bt new web email portal
if u haven't downloaded the new version of the outlook app for 2024
new for old outlook
https://youtu.be/bmxWnlv9zrI?si=tR7SoZoGXJM08WuL
outlook for windows
windows lost the yahoo 6 digital code as there is no btyahoo for a option as the have gone web mail
outlook for android :
and 23sec in pop3 email creation
outlook app for Mac
as u see in outlook for Mac is shows around 15sec in on right hand top corner there is a imap option if u click o it and it give u the option for pop3 or pop
thank u theriddlerz  hope I haven't board you all my aviator. is planetarylight
3 REPLIES 3
Message 2 of 4
Re: email on outlook
Bad advice, not only is POP3 unsuitable for most people as mail doesn't sync between devices, it is totally incorrect that IMAP doesn't work with BT email.
Message 3 of 4
Sorry it is the only one that works for it to be used I am the same when by changed from btyahoo to webmail it’s like they have gone backwards rather than forward sorry it doesn’t work for multiple devices
theriddlerz my avatar is planetarylight
Message 4 of 4
The Outlook app (not to be confused with Outlook xxxx part of the MS Office suite) is a pretty poor app in any case.
Try Blue Mail on Android, Thunderbird on a PC and the native app on Apple devices.
