Message 1 of 5
sending email
When forwarding emails all the original formatting and pictures disappear, usually rendering message illegible - Why? What to do to fix it?
4 REPLIES 4
Message 2 of 5
Re: sending email
Stop using webmail and use a mail client (app) instead. Mozilla Thunderbird is free and highly regarded.
Message 3 of 5
Re: sending email
Thanks.
Except I don't like Mozilla, BT mail used to work fine with webmail and I use webmail without issues with all my other email addresses, So why has BT messed this up? Isn't there a fix for webmail?
Message 4 of 5
Re: sending email
Make sure that you have "Compose Messages in Rich Text Format" selected in your settings.
Message 5 of 5
Re: sending email
Great, thanks
