Message 21 of 24
Re: 3rd party router with Bt hub for digital voice
Way above my head but interesting to read, so thanks. I appreciate your time and expertise.
Regards
Message 22 of 24
Hi, I've a similiar setup as this, but on ff 900 I'm only achieving download speeds between 200-400
Uploads seem to be constant at 110
What.speeds are you achieving?
Message 23 of 24
@Checks
You do realise this is a three-month-old thread?  Plus, you’ve posted as a quote from earlier…which doesn’t seem to relate to this thread?
I would suggest the problem is probably the router you’re using.  As I mentioned in an earlier post, most older kit has a firewall throughput of only 300-400 Mb/s, (even if the ports are "gigabit").  Fine in the day when the day was 80/20 on FTTC but not up to FTTP speeds.
Message 24 of 24
Hi WSH,
                I followed your settings to set up my netgear RS700 router and now it works in router mode connected to my EE/BT smart hub 2 Fibre. Needed to keep the BT hub connected so as to use my digital landline. Thanks for the advice
