Message 1 of 2
8600
We have a 8600 quad system which has suddenly started to block genuine callers.  Anyone else had this problem?  Also both incoming and outgoing sound level has dropped?
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: 8600
Is caller ID still active on the line? If you disable the Call Control & call from your mobile, is the number displayed? There have been a few reports over time of the facility dropping off a line.
If CLI is working as it should then you may have to bite the bullet & reset the base station. Unfortunately that will likely wipe your contacts & blocked lists.
