Message 1 of 8
Announced calls
My phone has begun to make some calls 'announced'. I had nothing to do with it, and I don't want it. How can I stop it?
7 REPLIES 7
Message 2 of 8
Re: Announced calls
are you a BT broadband customer and if so are you on digital voice? which type/make of phone are you using?  this more likely to be a setting on your phone have you checked the manual?
Message 3 of 8
Re: Announced calls
Thanks for the reply.
No I'm not a BT Broadband customer, but I use a BT phone for the landline. I've scoured the settings for anything which mentions announced calls, with no luck. Any ideas?
Message 4 of 8
Re: Announced calls
I'm surprised to see that there is an accepted solution to my problem, as I haven't solved it. Read the manual doesn't do it for me. I'll look elsewhere.
Message 5 of 8
Re: Announced calls
What phone is it?
Message 6 of 8
Re: Announced calls
BT advanced phone Z trio
Message 7 of 8
Re: Announced calls
What company provide your telephone service , you say you are not a BT broadband customer , are you a BT customer for telephony or it’s just you happen to use a BT branded telephone instrument, and could just as easily have a Panasonic or other make of phone , so the only connection to BT is a BT branded handset ?
If it’s just a BT branded phone , the user manual is available on line and there are various 0800 type numbers for help using the product.
Message 8 of 8
Re: Announced calls
I use Zen for broadband and landline, so it's just a branded handset. I'll search for t he man ual. Thanks
