Message 1 of 10
BT 4600 additional Handset
One of my BT 4600  additional Hand sets display is permanently Illuminated . The other is not. Is there a setting to turn the illumination off, as I cant find anything in the settings. Strange that only one handset display is lit up?
9 REPLIES 9
Message 2 of 10
Re: BT 4600 additional Handset
Have you tried removing the batteries for a short while?
Message 3 of 10
Yes took them out for bout a minute
Anonymous
Not applicable
Message 4 of 10
Try a factory reset of the handset.
Message 5 of 10
Thanks will give a try.
Message 6 of 10
Nope reset didn't work.
Anonymous
Not applicable
Message 7 of 10
Does it do it both on & off the cradle?
Message 8 of 10
Yes it does
Anonymous
Not applicable
Message 9 of 10
Sounds like a fault then. Long shot but maybe leave the batteries out overnight & try in the morning. But I'd expect a factory rest to clear any such oddities. Nothing to lose though.
Message 10 of 10
OK will do that,  thank you all for your help.
