Message 1 of 4
BT 4600
My elderly parents have the BT4600. When they receive a call the base rings but the handset does not and I want to correct this
I have assumed that the correct thing to do would be to follow 'Turn handset tones on/off' The User guide says to go to settings then Handset tones. Handset tones is not one if the options to choose.
I'd appreciate any help you can give
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: BT 4600
Handset Tones would relate to the keypad. You want ringer settings as per P.67 of the manual.
Message 3 of 4
Re: BT 4600
Thanks for your reply but that doesn't make the handset ring
Anonymous
Not applicable
Message 4 of 4
Re: BT 4600
Maybe it's been accidentally set to Do not disturb?
