Message 11 of 17
Re: BT Digital Handset Screen
Many thanks for your help, its much appreciated. I have now downloaded a copy of the Essential Digital Home Phone manual so hopefully will stop asking questions on this forum but I now have one or two for the BT TV Box forum. Thank you
Message 12 of 17
I can't find the Accessibility settings. Under 'Menu' I get only 'Call Features', 'Alarm' and 'Settings'. I don't see 'Accessibility'. Am I looking in the wrong place?
Message 13 of 17
@ljhr  It depends on what phone you have, take a look at Message 5 and follow the link.
Message 14 of 17
I have the user guides referred in message 5. The advanced guide says:
'...press Menu. Then scroll down to get to Accessibility'.
But there is no Accessibility, only 'Call Features', 'Alarm' and 'Settings'.
Message 15 of 17
@ljhr  I have Advance Phone and just checked  with no problems.
Are you sure yours is Advance or Advance with Alexa?
Message 16 of 17
You're right! I have the Essential, not the Advanced. I have mixed up my user guides! Thanks so much.
Message 17 of 17
Hi
I've just read your post. I have the Essential Digital Voice  BT phone. In the user guide it says you can adjust the colour on the screen but there is no such option in the display settings. Maybe the colour option is only available on the Advance phone?
