Message 1 of 3
BT Digital Voice phones and Vodaphone.
I have fttp and was with BT and had BT Digital Voice Phones. Now moved to Vodaphone with Vodaphone Digital Voice, and the BT Digital Voice phones do not work.
Is there anyway I could keep my old BT router to act just as a phone server and connect it to the new vodaphone router to get them operational?
My old fashioned phones worked regardless of the service provider as there was "a standard". Seems strange that there isn't a standard for Digital Voice phones between the various providers, it's all VoIP at the end of the day. Progress I suppose.
2 REPLIES 2
Message 2 of 3
Re: BT Digital Voice phones and Vodaphone.
Message 3 of 3
BT Digital Voice phones will only work with BT Digital Voice, you'll need to use whatever Vodafone supply/support.
You'll also be requested to send the Smart Hub 2 back, it's BT equipment on loan whilst you're a customer, otherwise they will charge you.
