Message 1 of 7
Using DV phone in outhouse
Hi experts! I have digital voice service (after several weeks of delay) but want to use a handset in an outbuilding - at present I’m not able to do that, presumably because I’m too far from the hub. I had thought digital voice used WiFi but that can’t be the case as I have a strong signal over there. So they must be DECT. Question is: how can I set myself up to be able to use the DV handset in the outbuilding where my study is?? All thoughts welcome
Peter
6 REPLIES 6
Message 2 of 7
Re: Using DV phone in outhouse
Message 3 of 7
In a nutshell, you can't if the outhouse is out of DECT range of the hub.
Message 4 of 7
If you have a mobile phone you could divert your DV phone calls to your mobile while you are in your study. Call Divert is free with DV.
help/landline/all-about-call-diversion-for-digital-voice
Message 5 of 7
I had some sort of range extender once when using a dect phone on our analog line. Is this no longer an option? I guess that linked to the base rather than the hub which must make a difference!
Message 6 of 7
DECT range extenders for whatever reason, appear not to work with the BT hub DECT base station.
Message 7 of 7
if you cannot use the dect DV phone have a read at this post which gives a different solution using existing phone wiring
https://community.bt.com/t5/Home-phone-including-Digital/Correct-way-to-enable-all-BT-sockets-after-...
