Message 1 of 12
BT Home Essentials
Hi folks
Looking for some help. Trying to set up BT Hime Essentials for my Aunt. She only requires the calls package a£10 per month.
Unfortunately order won't go through online and I'm given a 0800 number to call.
When I call the given number, I'm told they can't do the call only package over the phone and it can only be completed online.
Any help.or tips would be greatly appreciated.
11 REPLIES 11
Message 2 of 12
Re: BT Home Essentials
Hi @phone1, welcome to the forum and thanks for posting.
Is it after you input the details NI number etc that the online order fails? If so it's best to check with the DWP to ensure they hold the correct details for your Aunt.
Cheers
John
Message 3 of 12
Hi John, @JohnC2
It's actually before that stage - just after I put in the postcode.
There's no current line in the house
Any help wpuld be great.
Message 4 of 12
Hi @phone1, thanks for that info. Are you getting this error? JohnC2_0-1672828743887.png
cheers
John
Message 5 of 12
That's it @JohnC2 !
Message 6 of 12
Hi @phone1, thanks, it looks like there's a technical issue with the website at the mo.
Did you try to place the order previously like yesterday? If so we'll need to look into this further.
If not, then try again later today and hopefully it should be up and running then and let us know how you get on.
cheers
John
Message 7 of 12
Hi @JohnC2,
Yes tried yesterday and again this morning - I'll try again later and jump on here if any issues.
yd
Message 8 of 12
Hi @phone1, yes please come back and if you're still unable to place the order we'll be happy to help you.
Cheers
John
Message 9 of 12
Hi @JohnC2
Hope you're well today.
Unfortunately I'm still having the same problem with trying to process the order:
Could I ask for your help again, please?
Many thanks.
Message 10 of 12
@phone1
Out of curiosity is the address on a FTTP Full Fibre only exchange?
Follow https://landlinesgo.digital/checkmyline and post the table of results here (minus address)
I've tested a few scenarios and for me it looks like if you are on a FTTP Full Fibre only exchange you see that error message but please do the above to help see why you get that error.
