Message 1 of 4
BT advanced digital phone with Alexa
Very new to BT advanced digital phone with Alexa.
Will I still be able to use my existing cordless home phone handsets if I connect a BT Alexa phone to my broadband?
Thanks in advance
3 REPLIES 3
Message 2 of 4
Re: BT advanced digital phone with Alexa
Thanks in advance
Yes, by plugging your existing system into the Smart Hub 2 phone socket.
The Alexa phone connects directly to the Smart Hub 2 using DECT.
Message 3 of 4
My current phone is connected via the hub already so it sounds as if i'm ok.
My contract was about to run out and I was offered the alexa phone which I accepted but didn't want to lose the use of my current multi handset phones.
Many thanks for the reply
Message 4 of 4
so do you have DV already?  the openreach phone socket on wall is no longer able to make phone calls?
https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-FAQs/td-p/2207485
These FAQ may help
