Message 1 of 4
BT digital home calls, sent and received, cut off (drop out) 15 or 20 seconds into the call. Why?
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: BT digital home calls, sent and received, cut off (drop out) 15 or 20 seconds into the call. Wh
@alphanumeric
Are you using the BT supplied handsets, or do you have a phone plugged into the Smart Hub 2 or Digital Voice Adapter?
Message 3 of 4
Using 2 BT supplied handsets, one plugged into Smart Hub 2. Using Double master socket, so no need for filters. Internet speed around 48Mb - was around 58Mb prior - some improvement.
Message 4 of 4
Do you still get the disconnections on the phone which is plugged directly into the phone socket on the back of the Smart Hub 2?
